Démarré par nErur, 10 Décembre 2013 à 23:11:25
« précédent - suivant »0 Membres et 1 Invité sur ce sujet
array(15) { [0]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(590) ["function"]=> string(9) "log_error" } [1]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(494) ["function"]=> string(12) "smf_db_error" } [2]=> array(3) { ["file"]=> string(39) "/home/capyxyzyvb/fpk/Sources/Errors.php" ["line"]=> int(138) ["function"]=> string(12) "smf_db_query" } [3]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(590) ["function"]=> string(9) "log_error" } [4]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(494) ["function"]=> string(12) "smf_db_error" } [5]=> array(3) { ["file"]=> string(39) "/home/capyxyzyvb/fpk/Sources/Errors.php" ["line"]=> int(138) ["function"]=> string(12) "smf_db_query" } [6]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(590) ["function"]=> string(9) "log_error" } [7]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(494) ["function"]=> string(12) "smf_db_error" } [8]=> array(3) { ["file"]=> string(40) "/home/capyxyzyvb/fpk/Sources/LoadAds.php" ["line"]=> int(298) ["function"]=> string(12) "smf_db_query" } [9]=> array(3) { ["file"]=> string(40) "/home/capyxyzyvb/fpk/Sources/LoadAds.php" ["line"]=> int(239) ["function"]=> string(13) "updateAddHits" } [10]=> array(3) { ["file"]=> string(40) "/home/capyxyzyvb/fpk/Sources/LoadAds.php" ["line"]=> int(95) ["function"]=> string(7) "showAds" } [11]=> array(3) { ["file"]=> string(56) "/home/capyxyzyvb/fpk/Themes/default/Display.template.php" ["line"]=> int(67) ["function"]=> string(14) "show_threadAds" } [12]=> array(3) { ["file"]=> string(37) "/home/capyxyzyvb/fpk/Sources/Load.php" ["line"]=> int(2786) ["function"]=> string(13) "template_main" } [13]=> array(3) { ["file"]=> string(37) "/home/capyxyzyvb/fpk/Sources/Subs.php" ["line"]=> int(4174) ["function"]=> string(15) "loadSubTemplate" } [14]=> array(3) { ["file"]=> string(30) "/home/capyxyzyvb/fpk/index.php" ["line"]=> int(189) ["function"]=> string(6) "obExit" } } Error loop.array(5) { [0]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(590) ["function"]=> string(9) "log_error" } [1]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(494) ["function"]=> string(12) "smf_db_error" } [2]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(802) ["function"]=> string(12) "smf_db_query" } [3]=> array(3) { ["file"]=> string(40) "/home/capyxyzyvb/fpk/Sources/Session.php" ["line"]=> int(187) ["function"]=> string(13) "smf_db_insert" } [4]=> array(1) { ["function"]=> string(12) "sessionWrite" } } Error loop.array(2) { [0]=> array(3) { ["file"]=> string(39) "/home/capyxyzyvb/fpk/Sources/Errors.php" ["line"]=> int(301) ["function"]=> string(9) "log_error" } [1]=> array(1) { ["function"]=> string(17) "smf_error_handler" } } Error loop.
