array(10) { [0]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(590) ["function"]=> string(9) "log_error" } [1]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(494) ["function"]=> string(12) "smf_db_error" } [2]=> array(3) { ["file"]=> string(39) "/home/capyxyzyvb/fpk/Sources/Errors.php" ["line"]=> int(135) ["function"]=> string(12) "smf_db_query" } [3]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(590) ["function"]=> string(9) "log_error" } [4]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(494) ["function"]=> string(12) "smf_db_error" } [5]=> array(3) { ["file"]=> string(39) "/home/capyxyzyvb/fpk/Sources/Errors.php" ["line"]=> int(135) ["function"]=> string(12) "smf_db_query" } [6]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(590) ["function"]=> string(9) "log_error" } [7]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(494) ["function"]=> string(12) "smf_db_error" } [8]=> array(3) { ["file"]=> string(40) "/home/capyxyzyvb/fpk/Sources/Display.php" ["line"]=> int(390) ["function"]=> string(12) "smf_db_query" } [9]=> array(3) { ["file"]=> string(30) "/home/capyxyzyvb/fpk/index.php" ["line"]=> int(186) ["function"]=> string(7) "Display" } } Error loop.array(5) { [0]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(590) ["function"]=> string(9) "log_error" } [1]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(494) ["function"]=> string(12) "smf_db_error" } [2]=> array(3) { ["file"]=> string(46) "/home/capyxyzyvb/fpk/Sources/Subs-Db-mysql.php" ["line"]=> int(802) ["function"]=> string(12) "smf_db_query" } [3]=> array(3) { ["file"]=> string(40) "/home/capyxyzyvb/fpk/Sources/Session.php" ["line"]=> int(183) ["function"]=> string(13) "smf_db_insert" } [4]=> array(1) { ["function"]=> string(12) "sessionWrite" } } Error loop.array(2) { [0]=> array(3) { ["file"]=> string(39) "/home/capyxyzyvb/fpk/Sources/Errors.php" ["line"]=> int(301) ["function"]=> string(9) "log_error" } [1]=> array(1) { ["function"]=> string(17) "smf_error_handler" } } Error loop.
